2026-01-26 21:29:29
3.6k
310
GM - (Gundam Requiem Version)
@User_2038979_2038979
描述
  describe
TPU关节高达系列第二弹。  The second installment in the TPU joint Gundam series.
RGM-79G 陆战型吉姆  RGM-79G Ground Combat GM
原创建模 吉姆  Original modeler Jim
采用TPU关节和独家齿轮关节技术,确保提供长期温度的阻尼、减少零件数量,并提升组装体验。
Utilizing TPU joints and exclusive gear joint technology, it ensures damping at long-term temperatures, reduces the number of parts, and enhances the assembly experience.
简单组装说明  Simple assembly instructions
安装TPU关节时,请按照以下步骤操作:  When installing the TPU joint, please follow these steps:
  1. 先将TPU关节套插入球形关节。  First, insert the TPU joint sleeve into the ball joint.
  2. 然后将组装好的关节安装到指定位置。  Then install the assembled joints into the designated positions.
  3. 6个TPU关节套都是通用的。可以通用  All six TPU joint sleeves are interchangeable.
  4. 按对应颜色,无需自己上色,所见即所得  Select the corresponding color; no manual coloring is required—what you see is what you get.
利用齿轮关节,大量零件都可以一体打印,极大的减少了组装步骤
By utilizing gear joints, a large number of parts can be printed in one piece, greatly reducing assembly steps.
及其简单的安装,按图片将零件插入对应Y型槽即可,无需胶水
It's extremely easy to install; simply insert the parts into the corresponding Y-slots as shown in the picture. No glue is required.
由于不同的温度 材料 湿度 等不可控因素,如果组装松垮,垫入纸片再组装即可
Due to uncontrollable factors such as varying temperatures, materials, and humidity, if the assembly is loose, simply insert paper pads and reassemble.
Gundam
Mobile Suit
Full body articulati
