2026-08-30 21:45:49
2.3k
280
GTA VI (6) lightbox
@Werokk_3269339
Grand Theft Auto VI Style Palm Tree Light Box
Bring the iconic GTA VI neon aesthetic right to your desk or gaming setup with this custom-designed 3D printable light box. Featuring the distinctive "VI" typography intertwined with tropical palm tree silhouettes and glowing vibrant pink backlighting, this model is optimized for easy 3D printing and assembly.
  • Gamer Aesthetic: Perfectly captures the modern Miami-inspired neon sunset vibe.
  • Clean Geometry: Designed with clean lines and separated panels for straightforward slicing and multi-color or multi-material execution.
  • Lighting Ready: Engineered with internal spacing specifically tailored to house standard LED strips or backlight modules.
Printing Recommendations
  • Orientation: Print body parts flat on the bed for maximum structural stability.
  • Supports: Minimal to none required depending on your printer's bridging capabilities, keeping post-processing to a minimum.
  • Filament Colors:
  • White / Light Grey: For the outer chassis/housing.
  • Black: For the front palm tree and letter silhouettes.
  • Translucent Pink / White: For the diffuser panels to achieve that classic neon glow.
Assembly & Electronics
  1. Assemble the outer casing parts using standard alignment pins or glue if necessary.
  2. Route your choice of USB-powered LED strip lights or flat panel LEDs through the back channel.
  3. Secure the diffuser and silhouette faceplates into the front grooves.
GTA
GTAVI
Lightbox
grandetheftauto
