Wall Mount for Gundam 1/144 Model
This wall mount is designed specifically for Gundam models in 1/144 scale, allowing you to display your model safely and stylishly on the wall.
The mount is easy to install and is recommended to be attached using high-quality double-sided tape, which provides excellent holding strength and keeps the model firmly in place.
The supporting arm features a rotating mechanism, allowing you to adjust the position and angle of the model for the best visual effect.
The mount was 3D printed using PLA material with a 0.2 mm layer height, ensuring a good balance between strength, durability, and surface quality.
Perfect for collectors who want a clean, modern way to showcase their Gundam models.
