2026-10-25 02:44:27
55
Ghost Pumpkin LED Tealight Holder
@g4brix_1535559
A Halloween pumpkin-style house with a small ghost on top, designed to hold a classic LED tealight. An opening at the bottom provides access for inserting the light. The model was printed in white PLA and hand-colored with acrylic markers; the simple surfaces are well suited to personal coloring. I am pleased with the result, even though I am not an experienced decorator, and feedback is welcome.
The slicer project includes tree supports that help support the pumpkin through the lower opening. They may not be necessary inside; I found them manageable to remove. Check the overhangs and your printer before disabling them, and remove supports carefully after printing.
Print settings from the supplied 3MF: Anycubic Kobra S1, 0.4 mm nozzle, 0.20 mm layer height, 15% infill, 2 walls, automatic tree supports, 5 mm auto brim. Sample material: white PLA.
Use an LED tealight only. Do not use a real candle or open flame.
Halloween
Pumpkin
Ghost
LED Tealight Holder
3D Printed Decor
