Keep your golf ball perfectly aligned with this Golf Ball Marker / Alignment Guide, designed to help golfers position and mark the ball consistently before putting or practicing. The compact 3D-printable design features three curved alignment guides that work around the golf ball while the wide base keeps the marker stable on the surface.
The model is lightweight, compact, and easy to print, making it a useful accessory for golfers, putting practice, and golf enthusiasts.
📦 3MF File Includes
- Golf Ball Marker / Alignment Guide
- Optimized orientation for easy printing
- Compact, lightweight design
- No supports required
- Suitable for PLA, PLA+, PETG and similar filaments
🖨️ Short Print Profile
Layer Height: 0.20 mm
Nozzle: 0.4 mm
Walls: 3
Top/Bottom Layers: 4
Infill: 15–20%
Print Speed: 50–70 mm/s
Supports: Not Required
Bed Adhesion: Skirt or Brim if needed
Material: PLA / PLA+ recommended
⭐ Key Features
- ⛳ Designed for golf-ball alignment
- 🎯 Helps create consistent ball positioning
- 🖨️ Easy, support-free printing
- 💪 Stable base design
- 📦 Small and filament-efficient
- 🎨 Easy to customize with different filament colors
- 🏌️ Great for golfers and putting practice
