2026-07-23 20:07:37
1.9k
200
Grippy Broom Holder
@VC_Design_4324288
The Grippy Broom Holder is an upgraded version of the original Broom Holder, designed to provide even more holding force. It features four TPU ribbed grip inserts that are glued to the inside of the holder, creating extra friction to keep your broom securely in place.
Versions
The model is available in multiple sizes to fit different handle diameters:
  • Ø25 mm
  • Ø30 mm
  • Ø35 mm
Function
The snap-fit mechanism securely grips the broom handle, while the TPU inserts provide additional friction for an even stronger hold. The broom remains easy to insert and remove without slipping.
Assembly
  1. Print the holder and the 4 TPU grip inserts.
  2. Glue the TPU inserts into the designated recesses on the inside of the holder.
  3. Mount the holder to the wall using 2 screws.
Printing
  • No supports required
  • Easy and reliable print
  • Print the grip inserts in TPU for the best performance
A practical solution to keep your brooms and cleaning tools securely organized and always within easy reach. :)
broom
holder
mount
wallmount
tool
toolholder
stick
handle
organizer
printinplace
vcdesign
