2025-04-20 01:51:52
6k
754
Grippy Filament Clip
@Fletch_5269980
A universal filament clip that will hold any filament tight, grips every spool from cardboard to plastic, and works with every brand. This clip holds all 1.75mm filaments tight without any slippage. Designed to be used with any filament brand, I've tested this with a variety of brands and it has worked great. Brands tested include Bambu, Hatchbox, Elgoo, Overture, AnyCubic, Inland, and more.
Note: If you want to print more than 1 clip you'll need to clone it.
  • The filament grip was designed to have a smaller diameter than 1.75mm, but is able to bend when filament is inserted. This provides a tight grip that won't allow the filament to slide out (See image with a clip split in half)
  • Angled spool clip to fit and grip any spool tight.
  • Tapered outer edge so it won't pop off the spool when sliding it next to another spool.
  • Flared inner edge to easily slide the clip onto any spool.
clip
filament clip
spool
printer
filament
