2026-04-22 18:54:35
1.2k
26
Groot Fan Cover – Kobra 3 (V2)
@GorilloneChaddo_1876803
While customizing my printer, I felt that the stock fan cover looked a bit too plain for the overall aesthetic of my setup. I wanted something that could add personality without compromising functionality, so I designed this custom fan cover featuring a subtle Groot detail to give the print head a more unique and eye-catching look.
The result is a simple but effective upgrade that enhances the visual appeal of the printer while maintaining full compatibility and ease of installation.
This model is designed for:
• Anycubic Kobra 3
• Anycubic Kobra 3 V2
Inside the 3MF file, you will find two separate build plates:
• Type 1
• Type 2
This allows you to easily choose the correct version depending on your setup.
The Groot detail is integrated directly into the design to keep everything clean and durable, without the need for additional parts or assembly.
⚙️ Recommended Settings
Material: PLA or PETG
Infill: 15%
Seam Position: back
Brim: Mouse Ear
Skirt: optional
🖨 Printing Tip
During my first print, I used a bed temperature of 60°C, but I noticed that in colder environments or with slightly uneven build plates, adhesion could be improved.
If you experience similar conditions, I recommend increasing the bed temperature to 70°C for better first layer stability and overall print success.
🎁 Special Anycubic Discount
By purchasing through my affiliate link, you can use the following exclusive coupon code:
🧾 Coupon: WLOUTRVZCM
🎉 $15 OFF your order
👉 Visit the Anycubic Shop
Kobra
Kobra 3
Kobra 3 V2
ace pro
ams
multicolor
groot
marvel
3d printer part
upgrade
fan cover
accessories
print head
cooling
PDF
Groot Fan Cover Documentation – Kobra 3 (V2).pdf
54.23KB
