I give you my first bookmark print (be gentle). Happy printing!
Print at 100% infill with a layer height of 0.08mm with a base layer of 0.16mm
The Model is 50.8x109.93mm in size
You may print at higher layer heights below the Min Depth of 0.48mm
The Max Depth is 2.2mm and the Actual Depth is 1.8mm
Filaments Used:
PLA Gray Transmission Distance: 2
PLA Black Transmission Distance: 0.3
PLA Blue Transmission Distance: 3.5
PLA White Transmission Distance: 5
This print uses 4 unique filaments
Swap Instructions:
Start with Gray
At layer #9 (0.8mm) swap to Black
At layer #14 (1.2mm) swap to Blue
At layer #16 (1.36mm) swap to White for the rest.
