2026-09-30 22:23:13
3.6k
329
Halloween Crank-It Peekaboo Box — Ghost & Skeleton Automaton
@Arly1122_3986543
A hand-cranked Halloween automaton for your desk. Turn the white side crank and two eccentric cams on the internal shaft lift the figures on top: the little ghost pops up and down out of the jack-o'-lantern, while the sitting skeleton beside it bobs in rhythm. It's an eye-catching, stress-relieving kinetic toy with a see-through window so you can watch the cams turn as you crank. Multicolor parts split by colorway — olive green frame, orange pumpkin, white ghost and skeleton, black dot eyes — print on a multicolor system with no hand-painting needed.
A few assembly notes: the shaft, cams and crank snap together, but the pumpkin and the skeleton need to be glued onto the cam posts on top — keep glue away from the moving gaps. Supports around the little skeleton are a bit tricky to remove; take your time with flush cutters and tweezers so you don't snap the thin ribs or skull details. Print in PLA at standard layer height. Great as a Halloween desk piece or a fun gift.
halloween
automaton
kinetic-toy
crank-toy
mechanical
fidget-toy
pumpkin
ghost
skeleton
jack-o-lantern
snap-fit
desk-toy
万圣节
