BOM: Printed with ROSA3D Starter PLA Orange (Use LED tealights only for safety!)
Get ready for the spooky season with this adorable Halloween pumpkin tealight holder! Featuring a cute, minimalist carved face, this little jack-o'-lantern is the perfect quick print to decorate your desk, dining table, or window sill for autumn.
The top opening is designed with a standard 40mm diameter to perfectly accommodate common tealight candles. While you can use real candles (as shown in the photos, though always with extreme caution around plastic), we highly recommend using cheap battery-powered LED tealights for complete safety. The light glows beautifully from within, casting a cozy autumn vibe.
Key Features:
- Standard Size: The 40mm top opening is precisely sized for standard tealights (both real and LED battery-powered).
- Cute & Spooky: Features a minimalist, friendly jack-o'-lantern face.
- Scalable: Easily scale it up in your slicer to hold larger pillar candles, or scale it down just for decoration!
- Support-Free Magic: Designed with carefully angled internal overhangs so the central cavity prints flawlessly without any support material.
Printing Instructions:
- Orientation: Print normally, resting flat on its bottom.
- Supports: NONE. The internal candle pocket is optimized to print without supports.
- Safety Note: If using real fire tealights, ensure the flame is well above the plastic rim and never leave it unattended. LED tealights are strongly recommended!
