2024-09-29 20:11:14
19.8k
2.3k
Halloween Pumpkin
@SabreDesign_2037362
Modern Halloween Pumpkin decoration. The model is 90 mm tall and 123mm wide, the standard model can be scaled up to your liking and scaled down to about 75% and still print fine and fit a standard electronic tea light. I also included files for printing the pumpkin body and stem in seperate colours, you can simply glue the stem into the body. Additionally I added a 60% scale single body pumpkin in case you want the model even smaller, this does not fit a tea light however.
The inside of the model is hollow to save on filament and to allow the tea light to shine through when using translucent filaments. You will need tree supports and a brim on the inside.
If you want to support me or get commercial licenses you can join a patreon membership: https://www.patreon.com/SabreDesign
For one time support you can also buy me a coffe here: https://buymeacoffee.com/sabredesign
halloween
pumpkin
kurbis
kuerbis
ghost
spooky
tealight
lightup
light
deco
decoration
decor
