2026-10-18 23:19:16
114
Halloween Special Release: Jack The Scarecrow
@Betalab3D_4615623
Welcome to my Halloween special release! This miniature features a creepy scarecrow with a carved pumpkin head and a classic witch hat.
Optimized for FDM single-color printing, this model is designed specifically for the "Print & Paint" experience.
Lore:
An ancient scarecrow awakened by a forest witch. Wearing her pointed hat and bearing a glowing pumpkin head, it is the relentless guardian of the magical pumpkin patch, ready to strike down anyone who dares to trespass on Halloween night.
Model Details & Specs:
Base: 60mm diameter
Parts: Split into 4 parts for optimal FDM printing.
Style: Tabletop RPG / D&D Miniature, highly detailed for painting.
Assembly & Pinning Instructions (IMPORTANT):
To ensure a sturdy build, the shoulders are designed to be pinned to the torso.
Pinning material: Use scrap pieces of 1.75mm PLA filament as pins/inserts.
Tolerance warning: Due to FDM tolerances, the holes might be slightly tight or have minor stringing/blobbing. You may need to clean the burrs or slightly enlarge the holes using a 1.8mm hand drill bit.
Apply a drop of CA (super) glue on the filament pins before inserting them into the torso and shoulders. Let it cure before attaching the rest of the model.
Recommended Print Settings:
Layer Height: 0.12mm or 0.16mm
Supports: Tree supports Slim.
Material: Standard PLA, PLA+
Happy Printing and Happy Halloween!
halloween
scarecrow
pumpkin
figure
statue
miniature
