2026-10-01 23:19:31
551
30
Halloween Window Peeping Mummy
@PlaDreams_4057917
Window Halloween Decor creepy Mummy.
Important: use basic PLA as other filaments might not let the light through or even give a different light.
The goal here is not high quality, as the mummy needs to look rough, so use as large a layer height as possible for a quicker print.
For the base, use whatever you prefer, but I used a 0.6 mm nozzle. A 0.4 mm profile is also available.
You'll need an LED lamp, more commonly known as LED Lamp Kit 001. Nowadays you can buy them anywhere; just make sure they are 60 mm or less. New RGB LEDs are available, or you can print a diffuser if you wish to change the color.
Use a sticker, if you wish, to hold the LED in place. I didn't, and just placed the mummy on top.
Halloween
home decor
mummy
window decor
mummy decor
halloween decor
scary
halloween decoration
led lamp
