2026-08-20 11:01:52
590
45
Halloween Witch Cauldron Tealight Candle Holder
@Polimar3D_4901303
A minimalist, witchy cauldron tealight holder designed for functional home decor, spooky vibes, or Halloween setups.
Design Features
Optimized for FDM: Modeled to be printed upside down (flat rim directly on the build plate).
Standard Fit: Inner chamber fits 38 mm tealights (LED candles recommended for heat safety).
Detailed Finish: Features side handles and tripod legs with smooth geometry.
Recommended Print Settings
Orientation: Print upside down (flat top rim on the build plate)
Layer Height: 0.16 mm – 0.20 mm (0.12 mm for extra smooth curves)
Infill: 15% – 20% (Grid / Gyroid)
Walls/Perimeters: 2 to 3
Supports: Activated
Material: PLA, PETG, or ABS
Safety Note: Using LED battery-operated tealights is recommended to prevent material softening from open flames.
cauldron
tealight
candle holder
halloween
witch
tabletop
