2025-08-29 20:14:25
12.1k
647
Hamsters and the Treehouse Garden 仓鼠和树屋花园
@flowercat_5771384
仓鼠和树屋花园Hamsters and the Treehouse Garden Design Story:
设计背后的故事:
小时候幻想过的秘密树屋,如今真的能实现啦!我设计制作了一座 迷你树屋,不仅能当作观赏摆件,放大后打印还能成为小仓鼠的温馨小家。我并没有养小仓鼠,所以我也创造了一堆可爱的小仓鼠让它们生活在这充满神秘的树屋之中。
When I was a kid, I used to dream about having a secret treehouse hidden in the garden. Thanks to 3D printing, that childhood dream has finally come to life!
I designed a miniature treehouse that works perfectly as a decorative piece, but if you scale it up, it can also become a warm and cozy home for real hamsters. Since I don’t actually keep hamsters myself, I created a group of cute little 3D printed hamsters to bring this magical treehouse to life.
It’s a playful mix of childhood imagination and modern 3D printing—turning a fantasy into something you can actually hold in your hands.
整体设计是一棵大树托起的神秘树屋;一楼有带圆形门洞的小屋,方便小仓鼠进出休息;顺着小楼梯来到带护栏的露台,可以在这里晒太阳、放松;再顺着侧面小梯子上二楼,是一间带拱形门洞和烟囱装饰的小屋;大树的枝干蜿蜒而上,点缀着茂密的绿叶;底座上绿色草坪,营造自然氛围。
The treehouse is held aloft by a giant tree, creating a sense of mystery and wonder.
On the first floor, there’s a little house with a round doorway—perfect for hamsters to come and go, rest, or take a nap. A small staircase leads up to a cozy terrace with railings, where they can bask in the sun and relax.
Climbing the side ladder brings you to the second floor, a charming little house with an arched doorway and a decorative chimney. The tree’s branches wind upward, adorned with lush green leaves, while the base is covered in grassy turf, completing the natural, garden-like atmosphere.
所有部件均为 拆件打印,无需多色,简单易拼,新手也能轻松完成。
All parts are printed separately, with no need for multi-color printing. The assembly is simple and beginner-friendly—easy for anyone to put together.
仓鼠:
花园树屋已经建好,搬进来了一群新朋友,是一群仓鼠伙伴们,仓鼠们对新家充满了好奇心,看上去非常开心
Hamsters:
The garden treehouse is finally complete, and a group of new friends has moved in—a lively bunch of little hamsters! They’re full of curiosity about their new home, exploring every corner with excitement, and they look absolutely delighted.
仓鼠模型整体缩小至66%既可以制作小体型仓鼠~可以放进树屋的小房子~
By scaling the hamster model down to 66%, you can create smaller hamsters—just the right size to fit inside the little houses of the treehouse.
仓鼠模型是拆件打印,仓鼠脑袋可动,可以好奇的看各个方同和抬头,呈现不同的状态,后期还会更新替换的嘴部表情哟。
The hamster models are printed in separate parts, with movable heads that can peek around and look up, showing different playful poses. Future updates will even include replaceable mouth expressions!
胸口内部安装一颗磁铁,就可以吸住磁吸配件:目前更新了葵花子、爱心、金币,可以选择自己喜欢的来搭配哟~
磁铁尺寸是6*2mm;缩小版(缩小之66%)需要 4*2mm
A magnet is installed inside the chest, allowing them to hold magnetic accessories. Currently, there are sunflowers, hearts, and coins available—pick your favorite to mix and match!
The magnet size is 6 * 2mm; the reduced version (66% reduction) requires 4 * 2mm
尺寸说明:默认的整体高度是30cm左右,如果想真的给小仓鼠使用,建议放大150-200%来制作,可以自己根据需要的大小来放大尺寸~
打印设置:层高:0.20mm,填充密度:15%,打印材料:PLA,拆件组装,无需ACE多色。
支撑说明:
1.仓鼠头部组件需要开启支撑(支撑类型:普通网格;阈值角度25°,顶部Z距离0.16mm、顶面接触面层数4 、支撑/模型XY间距0.5mm),支撑易拆。)
2.树屋整体不需要支撑~!
平台附着:确保打印板足够干净,附着力更好,获得更好的呈现效果。同时可以降低打印速度来获得更好的打印质量~!
安装说明会在后面更新,喜欢的话请保持关注~
Size Description: The default overall height is around 30cm. If you want to use it for hamsters, it is recommended to enlarge it by 150-200%. You can enlarge the size according to your needs~
Printing settings: Layer height: 0.20mm, filling density: 15%, printing material: PLA, disassembled and assembled, no need for ACE .
Support instructions: 1. The hamster head component needs to be supported (support type: ordinary grid; threshold angle 25 °, top Z distance 0.16mm, top contact surface layer 4, support/model XY spacing 0.5mm), and the support is easy to remove. )
2. The treehouse as a whole does not require support~!
Platform attachment: Ensure that the printing board is clean enough, has better adhesion, and achieves better presentation effects. At the same time, it can reduce printing speed to achieve better printing quality~!
The installation instructions will be updated later, please stay tuned if you like~
组合仓鼠和树屋成为完整版本,一定会带给你惊喜,可以添加任何你喜欢的小动物到花园农场里面,其余的针织花链接可以去我主页看看,也可以点击下方链接
花田小猫 - Makeronline - More Than Fun
好啦~就啰嗦这些啦~没有完善的地方我也会在后续慢慢补充(时间太赶啦~)~有任何问题可以留言哟~你的喜欢是对我最大的支持~非常感谢~!
Combine the hamsters and the treehouse to create a complete set—it’s sure to bring you joy! You can even add any other little animals you like to the garden or farm. For the rest of the knitted flower collection, feel free to check out my profile or click the links below.
That’s all for now! I’ll continue to improve and add more details over time (things have been a bit rushed~). If you have any questions, leave a comment—I really appreciate your support, and your enjoyment is the biggest motivation for me. Thank you so much!
感谢大家的喜欢和支持~安装示意图完成啦
Thank you all for your liking and support. The installation diagram is now complete
Tree House Garden 树屋花园
Mobile hamster 可动仓鼠组装示意图
Hamster
miniature model
ornament
tree house
assembly toy
toy
cute
building
house
仓鼠
可爱
微缩模型
树屋
装饰
宠物房子
pet house
组装玩具
可动玩具
益智
房子
