2026-10-04 17:40:56
722
50
Happy Halloween Lightbox
@ArgiCZ_2798409
Design Concept
A fun Happy Halloween Lightbox featuring a spooky bat, ghost and smiling pumpkin. The sign is designed to look great both as a daytime decoration and when illuminated in the dark.
The bat can optionally be printed in a different color and illuminated as well, giving you even more possibilities for customization.
Use
Perfect as a Halloween decoration for:
- Home and living room
- Halloween parties
- Windows, shelves and tables
- Spooky seasonal displays
Printing Suggestions
- Layer height: 0.2 mm
- Infill: 15%
- Nozzle: 0.4 mm
- Black filament is recommended for the main body.
- Orange filament works great for the lettering and pumpkin.
- White filament is recommended for the ghost.
- The bat can be printed in a different color than black, allowing the LED strip to shine through it too.
Assembly Instructions
1. Install the LED strip around the inner edge of the back part of the decoration.
2. The front part simply snaps into the back part, holding everything securely in place.
3. If you want to use an external power supply, you can easily add a cable opening to the back part directly in the slicer. Simply create a hole where needed and feed the LED strip cable through it.
4. You can also position an additional section of the LED strip behind the bat if you want it to glow as well.
This design gives you plenty of freedom to customize the LED placement and power connection to suit your setup.
halloween
halloween decor
halloween lightbox
home decor
decorative
decoration
lightbox
led light
bat
pumpkin
ghost
jack o lantern
spooky
creepy
scary
gift
party
multicolor
