2026-09-20 14:02:00
315
14
Heavy Armor Knight
@Meowcraft_2417143
1: The printing orientation of the helmet has been adjusted, and the head buckle from dummy13 is retained.
2: The buckles of the shoulder armor and shoulder parts are recessed inward to reduce clipping and increase articulation.
3: A new standard shoulder armor is designed to create a dragon scale effect (if you are uncomfortable with dense patterns, you can just use the original shoulder armor 0.0).
4: The armor on the upper arm and elbow has been stretched to provide some coverage for the elbow joint, improving the previous issue of exposed hollow gaps at the elbow.
5: The buckles of the waist side skirt armor have been reinforced.
6: The side skirt armor also features a dragon scale effect (if you are uncomfortable with dense patterns, you can just use the original side skirt armor 0.0).
7: The front and rear skirt armors now have articulated joints, which no longer interfere with leg movement, allowing for more poses. You can even use it as a pen holder.
8: The buckles of the hips have been redesigned for a more secure fit, but it is recommended to use glue for better strength.
9: The grooves of the knee armor have been redesigned to reduce interference and make installation easier, but it is recommended to use glue for better strength.
10: Added a Halloween pumpkin head.
11: The printing orientation of the weapon parts has been adjusted for easier printing.
12: Added new armored hands.
Note: For the sake of proportions and assembly, the lengths of some skeleton parts have been adjusted, so the skeleton is not compatible with the original dummy 13.
Most of the supports for the skirt edges and the main body can actually be removed. I added a lot of skirts and supports to ensure printing success, so please adjust them as you see fit.
Modifications:
1: The printing plane of the helmet part was adjusted, and dummy13 was used. Head buckle
2: Shoulder armor and shoulder buckle are retracted inward to reduce the gap and increase the mobility
3: New shoulder armor is made to show a dragon scale effect (if you feel that you are afraid of dense, you can still use the original shoulder armor 0.0)
4: The upper arm elbow armor is stretched to cover the elbow joint to improve the hollow elbow joint gap
5: The buckle of the waist side skirt armor is reinforced
6: The side skirt armor also has a dragon scale effect (if you feel that you are afraid of dense, you can still use the original side skirt armor 0.0)
7: The front and rear skirt armors have movable joints, which will no longer interfere with the movement of the legs and can make more poses.You can even use it as a pen holder
8: The buckle of the hips has been redesigned to make the installation more secure, but if you want to maintain better strength, it is recommended to glue
9: The groove of the knee armor has been redesigned to reduce interference and make it easier to install, but if you want to maintain better strength, it is recommended to glue
10: Added Halloween pumpkin head
11: The printing plane of the weapon part has been adjusted for easy printing
Note: For the sake of proportion and installation, some of the skeletons have been adjusted in length, so the skeleton is not compatible with the original dummy 13.
The skirt and most of the support of the body can actually be removed. I added a lot of skirts and supports for the success rate of printing. Please adjust them by yourself
Heavy Armor Knight
soldier
middle Ages
