2026-10-20 03:50:22
147
Helleborus lace full face mask
@TheMatterBureau_3869887
Perfect for Halloween, costume parties, photoshoots, festivals and alternative fashion.
Very fragile, be careful when removing the supports!
Sizing reference:
  • Cheek width: 14 cm
  • Eye width: 12 cm
  • Forehead to chin length: 19 cm
These are my personal face measurements for reference; fit may vary depending on your facial proportions and the specific design.
Adjusting the Fit with Heat:
If you need to adapt the mask to your face shape, you can carefully reshape the plastic using a hairdryer:
  3. Once the plastic becomes bendy but is not melting, carefully reshape it.
  4. Hold the new shape until it cools and hardens.
Heat warning: Heated plastic can cause burns. Never touch hot areas directly or put on a warm mask. Avoid overheating, work in a well-ventilated area, and check your filament's heat resistance before reshaping.
Repairing Broken Parts:
halloween
fairy
flower mask
botanical
full face mask
