2026-10-25 23:14:24
32
Hungry Undead – Chibi Halloween Zombie
@drakeforge3d_5567152
This little zombie has found his favourite Halloween snack! Holding a wrinkled brain in both hands, this chibi character combines spooky details with comically oversized proportions.
An oversized bald head, a hungry open mouth, missing teeth, and ragged clothing give him plenty of undead personality. Chunky boots and a hunched pose complete the look, while sculpted tears, facial creases, and brain folds add detail from every angle.
A fun addition to Halloween displays, horror collections, or a spooky desk setup. Keep him in a single colour to showcase the sculpting, or paint the skin, clothes, and brain for an extra playful finish.
Designed for FDM printing with supports.
   Guide
1. DRY THE FILAMENT
  • Recommendations:
Undead
chibi
toy
halloween
halloween monster
halloween decor
halloween zobmie
zombie
spooky
creepy
