2026-10-10 22:15:44
199
IKEA SKÅDIS Multimeter Holder & Probe Organizer
@Spokoyniy7_4227545
A practical and compact wall mount set for holding a digital multimeter (designed around the VC61A and similarly sized models) alongside its probes on an IKEA SKÅDIS pegboard. The set consists of two independent modular pieces: a main body basket/holder and a dedicated dual probe clip.
🔑 Key Features
  • IKEA SKÅDIS Compatible: Designed to fit standard IKEA SKÅDIS slot dimensions seamlessly.
  • Precise Pocket Dimensions: Internal dimensions are 40 mm × 82 mm with a depth of 80 mm (fits VC61A and similar multimeter bodies perfectly).
  • Unobstructed Port Access: Open-bottom design leaves the front lead jacks completely accessible while mounted.
  • Dedicated Probe Organizer: Double clip holder keeps test leads neatly secured in an upright position.
  • Easy Printing: Geometry is fully optimized for clean printing without required support structures.
⚙️ Recommended Print Settings
ParameterRecommended ValueMaterialPETG / PLA / ABS / PCTGLayer Height0.2 mmInfill15% – 20% (Grid / Gyroid)Wall Loops / Perimeter3–4 walls (for strong hook strength)SupportsNone (Print flat on bed)
skadis
ikea
