I redesigned this silica storage box to make handling silica much more convenient. Each compartment features a screw-on lid, which can be swapped out for either a funnel (for easy filling) or a spout (for controlled emptying).
To fit two boxes inside one Samla container, you’ll need to print the following parts:
- 2 × Tray 1
- 2 × Tray 2
- 2 × Cover 1
- 2 × Cover 2
- 4 × Caps
You can also print funnels and spouts as needed.
If you want to design your own caps/spouts/funnels you simply need to add a M24.4mm screw with 3mm pitch over a height of 5mm.
Based on the model by Nordlicht:
And the remixed lid by krkan:
https://www.printables.com/model/601058-ikea-samla-22l-dry-storage-box-with-silica-reservo
