2026-10-05 00:47:41
185
IKEA Skådis — Second Batch / New Release
@Spokoyniy7_4227545
A dedicated description for the new batch of modular organizers designed specifically for the IKEA Skådis pegboard system. All models share a striking two-color theme (red body with contrasting yellow accent rim) for enhanced visibility and workshop aesthetics.
📦 Included in Batch #2:
  1. Compact USB Drive, Card Reader & Adapter Holder
  • Universal Slot Design: Engineered to fit storage devices of various thicknesses—from ultra-slim metal thumb drives (Netac, etc.) to wider plastic drives, card readers, and Type-C adapters.
  • Angled Access: Holds drives vertically at a slight angle so they don't block each other, making it easy to spot and grab the exact drive you need.
  1. Deep Organizing Pockets for Daily Tools
  • Spacious Capacity: Designed for vertical storage of taller and bulkier hand tools.
  • Versatile Use: Perfect for deburring tools, cleaning brushes, screwdrivers, voltage testers, tweezers, markers, and scissors.
  • Visual Accent: The bright yellow top rim serves as a quick visual guide when returning tools during work.
  1. Upper Shelf Rack for Tall Storage Tubes
  • A dedicated rack module designed to hold longer transparent tubes/vials containing drill bits, nozzles, cleaning needles, or small hardware.
🛠 Key Features & Mounting:
  • Precise Skådis Fit: Hooks are tailored specifically for IKEA Skådis oval slots—a snug fit that won't lift off the board when pulling tools out.
  • Hardware-Free: Mounts directly into the pegboard without any screws or additional fasteners.
  • Durable Construction: Reinforced hooks built to endure daily workshop use.
🖨 Recommended Print Settings:
  • Material: PETG or PCTG (recommended for hook strength and flexibility), or PLA / ABS.
  • Dual-Color Printing: Achieved via a simple manual layer pause (filament swap right before the top rim) or using multi-material systems (AMS / MMU).
  • Layer Height: 0.2 mm.
  • Walls / Perimeters: 3–4 perimeters (essential for hook structural strength).
  • Infill: 15–20% (Gyroid).
  • Supports: None needed with correct orientation on the build plate.
skadis
ikea
