2026-10-03 22:14:58
163
IKEA Skådis Tool Holders & Shelves Collection
@Spokoyniy7_4227545
A growing collection of practical, sturdy 3D-printable holders, mounts, and shelves designed specifically for the IKEA Skådis pegboard system. Built to optimize workshop organization and keep your most essential tools within arm's reach.
🔄 Work in Progress: This project will be continuously updated with new functional modules, organizers, and holders as needs arise. Don't forget to Like / Bookmark to stay updated with new releases!
📦 Included in the Current Release:
  1. Digital Caliper Holder
  • Custom-tailored geometry for digital calipers (fits standard 150mm calipers such as Shahe IP54).
  • Securely cradles the body to eliminate wobble and prevent accidental falls.
  1. Side Cutter / Flush Cutter Holder
  • Ergonomic center-support mount tailored for flush cutters and pliers.
  • Allows quick, single-handed tool insertion and retrieval.
  1. 3D Printer Nozzle & Wrench Organizer Shelf
  • Top Tier: Slots designed to fit 4 standard transparent storage tubes (ideal for storing spare nozzles, micro drills, or extractors).
  • Bottom Slot: Integrated tray engineered to hold an L-shaped nozzle wrench or hex key.
🛠 Key Features:
  • Precise Fit: Hooks and alignment tabs are engineered specifically for IKEA Skådis oval slots.
  • Hardware-Free Mounting: Snaps directly into the board—holds firm and won't lift when removing tools.
  • Durable Design: Reinforced hooks engineered for daily workshop use without the risk of snapping.
🖨 Recommended Print Settings:
  • Material: PETG, PCTG, PLA, or ABS (PETG/PCTG recommended for optimal hook flexibility and layer adhesion).
  • Layer Height: 0.2 mm (0.16 mm for smoother surface finish).
  • Walls / Perimeters: 3–4 perimeters (crucial for hook structural strength).
  • Infill: 15–20% (Gyroid or Grid).
  • Supports: None needed with optimal orientation (or minimal tree supports under hooks depending on slicer setup).
Have ideas or requests for specific tool mounts? Feel free to drop a comment!
