2026-07-07 06:34:42
1.1k
116
Imperial AT-ST Scout Walker Star Wars Replica
@dharian_5531540
Watch out for rolling logs on Endor! Bring the Empire's iconic "Chicken Walker" straight to your desk.
This is a highly detailed, 3D-printable scale model of the All Terrain Scout Transport (AT-ST) from the Star Wars saga. Featuring its signature lightweight, twin-legged design, a fully armored command cabin, and chin-mounted twin blaster cannons, this model perfectly captures the industrial, utilitarian look of the Imperial military machine.
This version has been specifically engineered for single-color printing. You don’t need an AMS or complex multi-material setup to achieve a stunning result. The model utilizes deep, pronounced panel lines, mechanical joints, and highly detailed armor plating that rely on natural shadows and highlights to make the details pop naturally using just a single spool of filament. It has been tolerance-tested on Anycubic FDM printers (such as the Kobra, Vyper, or Mega series) to ensure it handles the retraction transitions between the narrow legs and the main cabin without excessive stringing.
Model Features
  • Single-Color Optimized: Designed to maximize contrast and depth right off the print bed using standard grey, silver, or matte PLA.
  • Anycubic Slicer Calibrated: Geometrically optimized to handle the intricate mechanical details on the legs and weapon systems without causing layer shifts or blobs on standard Anycubic hardware.
  • Iconic Stance: The model captures the dynamic, scanning walk of the scout transport, making it an excellent display piece for your gaming setup or office desk.
Recommended Print Settings
  • Layer Height: 0.12mm to 0.16mm is highly recommended to cleanly capture the fine mechanical greebles around the leg joints and the sharp angles of the cockpit.
  • Infill: 15% (Gyroid or Grid provides excellent internal stability to keep the tall model rigid).
  • Supports: Yes, supports are required under the main cockpit pod, the chin cannons, and the upper leg joints. Tree/Organic supports configured in your preferred slicer (Anycubic Next, Cura, or PrusaSlicer) are highly recommended for clean, effortless removal.
  • Brim: A 5mm to 8mm outer brim is highly recommended to keep the feet firmly anchored to your Anycubic print bed, preventing any wobbling as the printer builds the tall cockpit cabin.
StarWars
ATST
Imperial
Empire
SciFi
Vehicle
Miniature
Replica
DeskToy
Model
Geek
Movie
PopCulture
EasyPrint
Endor
Walker
ewok
