2026-07-05 22:39:06
791
86
Imperial TIE Interceptor Replica from Star War
@dharian_5531540
Interrupted a Rebel convoy? Deploy the Empire's fastest starfighter straight to your desk!
This is a highly detailed, 3D-printable scale model of the deadly TIE Interceptor from the Star Wars saga (prominently featured in Return of the Jedi). With its signature dagger-like solar array wings, aggressive forward-swept profile, and quad wingtip laser cannons, this model perfectly captures the lethal elegance of the Imperial Navy's elite interceptor.
This version is completely engineered for single-color printing. You don't need a multi-material system, AMS, or automated filament changers to make this ship look incredible. The surface geometry features deep, pronounced panel lines, distinct cockpit frame ridges, and highly detailed solar panels that rely on natural shadows and highlights to pop sharply. It has been tolerance-tested to print seamlessly on Anycubic FDM printers (such as the Kobra, Vyper, or Mega series), minimizing retraction stringing across the wide wing gap.
Model Features
  • Single-Color Optimized: Designed to look museum-quality using just one spool of filament. The physical geometry maximizes contrast so the hull details stand out naturally right off the bed.
  • Anycubic Slicer Calibrated: Geometrically optimized to handle the retraction demands of the wide wing structure without excessive stringing or layer shifts on standard Anycubic extruder setups.
  • Balanced Geometry: The angled wings are structurally reinforced at the joints to ensure the model remains rigid and perfectly balanced for display on any flat surface.
Recommended Print Settings
  • Layer Height: 0.12mm to 0.16mm is highly recommended to cleanly capture the spherical curves of the central cockpit pod and the sharp edges of the dagger wings.
  • Infill: 10% - 15% (Gyroid or Grid provides excellent internal stability without adding unnecessary weight to the wings).
  • Supports: Yes, supports are required under the central cockpit pod and the connecting wing struts. Tree/Organic supports configured in your preferred slicer (Anycubic Next, Cura, or PrusaSlicer) are highly recommended for effortless, clean removal.
  • Brim: A 5mm outer brim is highly recommended for the wings if printed vertically, ensuring they stay firmly anchored to your Anycubic print bed.
StarWars
TIEInterceptor
Imperial
Empire
SciFi
Miniature
Replica
Starfighter
Vehicle
Geek
DeskToy
3DPrint
Model
Movie
PopCulture
