2025-01-04 14:24:53
852
32
Interactive Puzzle Coasters!
@IMakeThings_2993832
Puzzle #1 - Tangrams
Tangrams are puzzles where you try to fit all the pieces into the required shape. I printed the game pieces for my tangram in red.
Puzzle #2 - 15 Puzzle
The 15 puzzle is a 4x4 grid of sliding tiles with one spot open. The tile start in a random order and the goal of the game is to put the tiles back in order by sliding one tile at a time into the open spot. (Sorry for the bad description) In order for the puzzle to be solvable, you need to start with each pice in the spot as shown in the picture before you mix it up. I started printing the pieces in black but added a color change to yellow at 2.00mm
Puzzle #3 - Tilt Maze
The tilt maze is a game where you need to get the disc from the opening on one side to the other by tilting the coaster. I started printing the pieces in black but added a color change to blue at 1.10mm
Puzzle #4 - Path Puzzle
The path puzzle is a puzzle I thought of myself. The goal of the game is to rotate each path block to line up with the others. There can be no loose strands throughout the entire puzzle. In order for the puzzle to be solvable, you need to have each pice in the spot as shown in the picture. I started printing the pieces in green but added a color change to black at 1.10mm.
Other things:
- A base is needed for EACH puzzle coaster.
- The holder holds a set of four coasters.
puzzle
coaster
