JOJO Desk Lamp
Whether you need a reading light or decorative lighting, this desk lamp is perfect for both small and large spaces.
Designed with a articulated stem and adjustable lampshade, it allows for easy adjustment of the light output to suit your needs.
Style, simplicity, and functionality combine in this interior furnishing accessory, which can be used as a reading light above an office desk or even on coffee tables and bedside tables next to the sofa or bed.
The project:
The model is designed to use minimal supports and maintain a high-quality finish, which is significantly improved when using matte filaments. To achieve an excellent finish, I created print profiles with a 0.16 layer height using Anycubic matte PLA. Particular attention was paid to the technical aspects of offsetting holes, screws, and joints for quick and easy assembly. You can download assembly illustrations in the documentation section.
Everything you need to make the lamp is printable, you will only need the electrical part.
For wiring, you'll need:
Standard power cord with switch and plug (depending on your country)
E14 lamp holder to screw directly onto the lampshade
E14 250V bulb (use only: max 4W LED).
