2026-07-09 06:31:07
726
68
Jedi Starfighter Interceptor Star Wars Replica
@dharian_5531540
"May the Force be with your printer!" — Add the elegant interceptor of the Jedi Order to your fleet!
This is a highly detailed, 3D-printable scale model of the iconic Jedi Starfighter, famously piloted by Jedi Knights like Obi-Wan Kenobi, Anakin Skywalker, and Mace Windu during the twilight years of the Galactic Republic. Featuring its signature sharp, arrowhead delta-wing profile, a centralized cockpit canopy, and an integrated socket for an astromech companion, this model perfectly captures the speed and elegance of the Jedi fleet.
This version has been specifically engineered for single-color printing. You don’t need a multi-material system, AMS, or complex filament-swapping routines to get a beautiful result. Instead, the model utilizes deep, pronounced panel lines, crisp cockpit framing, and prominent engine details that rely entirely on natural shadows and room lighting to make the features pop sharply. It has been tolerance-tested on Anycubic FDM printers (such as the Kobra, Vyper, or Mega series) to ensure clean layer execution across its smooth, sloped hull plates.
Model Features
  • Anycubic Slicer Calibrated: Optimized to handle the retraction paths between the main fuselage, the dual rear stabilizer fins, and the forward laser cannons without causing excessive stringing or blobs.
  • Sleek Delta Silhouette: Captures the classic prequel-era aesthetic, making it a perfect standalone display piece for your gaming setup, office desk, or Star Wars collection.
Recommended Print Settings
  • Layer Height: 0.12mm to 0.16mm is highly recommended to cleanly capture the smooth sloped nose, the engine ridges, and the fine frames of the cockpit canopy.
  • Infill: 10% - 15% (Gyroid or Grid provides excellent internal stability without adding unnecessary weight to the rear engines).
  • Supports: Yes, supports are required under the main belly of the ship and the overhanging wings. Tree/Organic supports configured in your preferred slicer (Anycubic Next, Cura, or PrusaSlicer) are highly recommended for clean, painless removal.
  • Brim: A 5mm outer brim is recommended to keep the support structures and the sharp wingtips firmly stuck to your Anycubic print bed.
StarWars
Jedi
JediStarfighter
JediInterceptor
CloneWars
Republic
Spaceship
Starfighter
Miniature
Replica
Vehicle
SciFi
Geek
DeskToy
