2026-02-11 21:30:52
950
17
KT-009“铁鸦”轨道巡逻机(Aerospace Fighter)
@David007_2386050
太空轨道巡逻载具 | “铁鸦” KT-009
Space Orbital Patrol Vehicle | "铁鸦" KT-009
核心功能(Core Functions):
  • 长期轨道巡航与监视(Long-term orbital cruise and surveillance)
  • 快速拦截与区域拒止(Rapid interception and area denial)
  • 跨大气层无缝作战(Cross-atmosphere seamless operations)
动力系统(power system):
  1. 核能涡喷引擎 x2: 提供近乎无限的持续巡航动力。(Nuclear Turbofan Engines ×2: Provide nearly unlimited sustained cruise power.)
  2. 高推力涡喷发动机 x2: 保障大气层内高效机动与起降。(High-Thrust Turbojet Engines ×2: Ensure efficient maneuvering, takeoff and landing within the atmosphere.)
  3. 离子推进器 x2: 于外层空间实现高精度姿态调整与机动。(Ion Thrusters ×2: Achieve high-precision attitude adjustment and maneuvering in outer space.)
武器配置(Weapon Configuration):
  • 近程防御: 50毫米速射机炮 x2(Close Defense: 50mm Rapid-Fire Cannons ×2)
  • 主力打击: “歼星”级定向能炮 x2(Main Strike: "Star Annihilator" Class Directed Energy Cannons ×2)
  • 远程拦截: 粒子驱动弹 x6(Long-Range Interception: Particle-Driven Projectiles ×6)
 *“铁鸦”KT-009 — 轨道制空权的定义者。*(以上为虚构故事,仅供娱乐)
"Iron Raven" KT-009 — The Definer of Orbital Air Superiority.(Fictional content for entertainment purposes only.)
模型尺寸(Dimensions):
  • 整体长171毫米,宽193毫米,高101毫米;
  • Overall length 171 mm, width 193 mm, height 101 mm.
需要用到的工具(Tools required):
  • 胶水Glue
  • 尖嘴钳Needle-nose pliers
注意事项(Precautions):
  • 模型零件较多,打印前请清洁打印板,做好耗材烘干,并视情况涂点打印胶;
  • 所有零件均需要用胶水固定(轮胎除外),组装前请看下说明书;
  • 模型零件有的很小,所有从打印机拿下来的时候请小心,避免掰断;
  • This model has many parts. Please clean the print bed, dry the filament thoroughly, and apply some printing glue if necessary before printing.
  • All parts need to be fixed with glue (except the tires). Please read the instructions before assembly.
  • Some parts are very small. Please handle them carefully when removing them from the printer to avoid breaking.
飞机
战斗机
飞船
太空飞船
航天飞机
战机
航模
摆件
airplane
PDF
组装流程.pdf
5.19MB
