2026-04-10 19:52:34
4.4k
218
KX Z-axis stabilization bracket
@User_5991332
KX z轴稳定支架
固定使用10颗M3.5*10自攻丝进行固定
模型公差预留0.2-0.4mm
底座脚垫推荐TPU 进行打印
模型墙层数、填充尽量高一些
两侧卡扣安装时会比较难安装,可以适当用吹风机加热变弯后安装,趁还没有变凉,用M3.5*10自攻丝进行固定,然后静静等待冷却即可
For securing the KX Z-axis stabilizer,
use 10 M3.5*10 self-tapping screws for fixation.
Allow a tolerance of 0.2–0.4 mm in the model design.
It’s recommended to use TPU for the base pads.
Also, try to increase the number of layers and fill density in the printed model.
Installing the clips on both sides can be difficult. You can use a hair dryer to heat them slightly and make them bend before installation. Once they’ve cooled down, secure them with M3.5*10 self-tapping screws, then simply wait for them to cool completely.
