2026-08-27 17:27:29
660
58
Keychain stand
@Woodydesignart_1390472
Are you looking for the perfect solution to display your keychains or small gadgets at trade shows, craft markets, or simply on your desk? This modular display rack is designed to be functional, incredibly easy to assemble, and ultra-compact for transport.
Key Features
  • Smooth Rotation: Designed to house ball bearings, ensuring seamless 360° rotation for every level.
  • Modular Multi-Tier Design: Each tier is independent. You can choose to print 1, 2, or 3 tiers, depending on the available space or the number of products to display.
  • Optimized for markets: It disassembles and reassembles in seconds, taking up very little space in a box or suitcase.
  • Maximum Capacity: The arms feature anti-slip notches to neatly distribute dozens of keychains without letting them slide off.
Required Hardware
To complete the assembly and ensure the smooth rotation of the modules:
  • Bearings: 3× standard 608-type ball bearings (the classic ones used in skateboards/fidget spinners, 8×22×7 mm).
  • Glue (optional): No screws required! The parts are press-fit, but a drop of cyanoacrylate glue on the central rod joints ensures maximum sturdiness.
  • If you don't want to print the tubes and want to save time and material, you can use rigid 20mm electrical conduit.
Do you like this model?
Leave a like, add it to your collections, and share a photo of your print/display in the comments! Your support helps future projects.
