2026-09-03 16:24:27
1k
79
Knitted Flexible Fabric Patch 9x9
@bigovereasy_4575819
To make a color pattern, you will of course need automatic filament change. I did not use more than 2 colors (for the pattern itself)
For coloring, I select fill and set the maximum Smart fill angle. I specify the needed loops; since it's a separate element, it gets completely filled without touching the others. Gray filament is used for contrast.
👇 Click on the picture if the animation is not displaying for you.
I tried both at 100% scale with a layer height of 0.2 mm, and at 75% with a layer height of 0.16 mm.
To make the fabric look even better, I colored the internal connection (the top polygon) to match the top.
I applied adaptive layer height to the layer with loops for a better effect.
©Personal use only 💀
👉 Check My Boosty 👈
Join my Telegram! ⭐💬
knitted
flexible
fabric
patch
heart
pixel
