2025-04-09 06:43:53
77.4k
9.1k
Kobra S1 Combo ACE Pro - Poor Man's Riser
@FlabberQuestion_1327272
This is a minimalist riser designed to lift your Anycubic ACE PRO on top of your Kobra S1. This compact riser offers just enough elevation to improve usability without wasting filament on a full spacer block.
The Poor Man’s Riser—a stripped-down version that keeps things functional while being far more filament-efficient. It still supports the ACE PRO securely using the existing screw holes on the underside. You can reuse the screws that came with the ACE PRO during shipping for a clean and stable mount.
Design Details:
  • Elevates ACE PRO by 30 mm
  • Compact footprint for filament savings
  • Designed to mount to the ACE PRO using underside screw holes
  • Compatible with Kobra S1 top surface
  • Requires 4 screws (from ACE PRO packaging)
Since my ACE PRO is almost against the wall, my lid does not open all the way and only 90 degrees max. I have not tested it when the lid is all the way open, in case it would tilt backwards but seen users report this is not an issue.
Other Prints
Check out the Anycubic Kobra S1 Door handle
Check out the matching Anycubic ACE PRO Door Handle. Who doesn't like a match?!
KOBRA S1
S1 COMBO
ACE PRO RISER
ACE PRO
RISER
SPACER
POOR MEN
Jc.Li
S1 Combo ACE Pro Spacer(bracket) Optimized version 支架/增高架
