Hola Guys,
Recently, I'm facing the issue that I have more and more small tools and things for the printer, and just in common, and I also have limited space now, that's when the idea came that I can use my printer as some small storage. That's why I designed this model, so I can just throw a metal thing onto the side of the printer.
What do you need for assembly?
- Printed Front and Back part
- 5pcs M3 x 10mm countersunk screw
- 5pcs M3 x 5.7mm insert
- Soldering Iron (if possible, with the proper insert adapters)
What additions can you apply?
- D6 x 3mm magnet
- D10 x 2mm magnet
- 10mm magnetic strip
(Magnets, screws, and inserts can be bought from Aliexpress)
How to assemble?
- Apply the inserts to the Front panel holes. (For the soldering iron, I used 200°C)
- Screw together the Front and the back panel with the M3 x 10 screws
- Remove the two screws from the back panel of the printer
- Align the Front panel to the printer's front
- Snap the panel to the back of the printer
- Screw back the two screw from the back of the printer
- Push the magnets in place (This can be done before the assembly of the printer, also)
I'm planning to design more and more add-ons to the panels, and soon I'll upload the USB side panel also.
If you have any requests or ideas, feel free to contact me.
Br: rozsmix
