2026-05-03 23:50:03
16.1k
1.6k
Kobra X / Kobra 4 Anti-vibration Feet Mod
@Manethon_Sega_3814903
Want your Kobra X / Kobra 4 to feel more stable, vibrate less, and be noticeably quieter?
This is a simple upgrade that uses the well-known Bambu Lab anti-vibration feet concept — but made to fit your Anycubic setup.
What’s included
  1. Base adapter (snug fit): single-foot or double-foot version (your choice)
  2. TPU feet files (Bambu-style) in 3 stiffness levels (tested with 95A TPU)
  3. Tested before vs after: smoother motion + less vibration + quieter printer ✅
Installation (don’t panic, it’s easy)
  1. Remove the original feet
  2. Install the new base (single or double)
  3. Push in the feet — snug fit, no drama
  4. Afterwards, you will need to run the resonance calibration test.
Notes (read this so future-you doesn’t sigh)
  • Front & back feet: work with single + double base
  • Feet under the Z-axis: single base only
  • Prints in place, no brim, no supports
(Seriously… don’t use supports with my design. 😆)
  • I tested 5 stiffness levels and included the best 3 for any setup (softest worked best for me)
  • Hate TPU? Fair. You can also buy the original feet online and just print the base adapter
  • For my setup, using a single foot base gave me the best results.
Side note
Yes, I willingly spent an unreasonable amount of time, caffeine, and sanity making this. If it helps you, hit like. If it really helps you, coffee via Ko-fi is always appreciated. 😌☕
kobra X
KobraX
Anti-vibration
Feet
vibration
