2026-01-08 08:26:42
25.8k
3k
Kobra X Filament Deflector and Waste Bin
@ZeroDotCMD_3724579
Anycubic Kobra X filament deflector and waste bin. The filament deflector mounts directly to the back of the filament extractor and is secured with screws.
The filament waste bin is designed to fit snugly next to the Kobra X. It sits firmly under the edge of the base, ensuring it stays in place and does not shift during use.
Self Slicing : If self slicing it is recommended to use 3 walls instead of the default 2. It is also recommended to enable supports. Auto tree supports have worked well with these files.
Printing Material : It is highly recommended to print the deflector out of a material other than PLA. Recommended ASA, ABS, or PETG. PLA will work, however extracted filament may stick to the deflector.
Kobra X
Kobra X Bin
Kobra X Deflector
Filament Deflector
Filament Bin
Waste Bin
