2026-04-04 20:27:25
12.7k
1.4k
Kobra X Screen Frame Full Bin
@steelcityviking_4119230
Keep your tools close at hand!
Please note: this is designed for the "thick" screen version. Apparently, some KX models shipped with a thinner screen casing, which likely won't work with this model. If your screen is ~12.5mm at the thickest, it should (hopefully) work.
Warning: The space between the screen frame and print bed is very tight, make sure you verify there isn't any rubbing after installation! These longer versions of the bin make things even tighter because of the geometry of the screen.
What it is
Slightly different take on my Screen Frame Tool Tray with a full-length bin (instead of the 1/2 sized bin in Screen Frame Half Bin) offering a general-purpose storage bin instead of specific tool cutouts.
I've included 2 version - a "standard" (same as the Half Bin or Tool Tray Design), or a "deep" (roughly double the Half/Tool version). Printed example pics are of the "standard" version.
Printing Instructions
The geometry of the frame + tray can make this tricky to print without supports. If you have really dialed in bridges, you might be able to get away with it. I included supports in the provided print profile, specifically using PETG interfaces with a PLA model. Feel free to make whatever changes you see fit (the supports are across a pretty thin cross-section, so shouldn't be a problem for even default supports).
I also found myself printing these in 0.28mm layer height with good results, so I included profiles for that option as well.
I also include the STL if you'd prefer to play with the orientation and support settings yourself. Printing it with the frame facing down would also work well if using a transfer build plate or for a split color design!
kobra x
kx
screen protector
storage
tool bin
