2026-03-31 08:32:39
3.8k
207
Kobra X Screen Frame Tool Tray
@steelcityviking_4119230
Keep your tools close at hand!
Please note: this is designed for the "thick" screen version. Apparently, some KX models shipped with a thinner screen casing, which likely won't work with this model. If your screen is ~12.5mm at the thickest, it should (hopefully) work.
Warning: The space between the screen frame and print bed is very tight, make sure you verify there isn't any rubbing after installation!
What it is
This is a simple model to turn the screen into an attachment point for a small tool tray. The model is build for the stuff I keep handy around my printer - a scraper, snips, and some tweezers.
Looking for something a little more flexible? Check out Screen Frame Half Bin or Full Bin! Same frame, different storage solution.
Printing Instructions
The geometry of the frame + tray can make this tricky to print without supports. If you have really dialed in bridges, you might be able to get away with it. I included supports in the provided print profile, specifically using PETG interfaces with a PLA model. Feel free to make whatever changes you see fit (the supports are across a pretty thin cross-section, so shouldn't be a problem for even default supports).
I also include the STL if you'd prefer to play with the orientation and support settings yourself. Printing it with the frame facing down would also work well if using a transfer build plate or for a split color design!
kobrax
kx
tooltray
