2026-05-19 03:09:09
810
30
Kumiko Style Japanese Lantern
@PlaDreams_4057917
Now with new patterns:
Choose blank or with pattern in your white panels.
08/09/26
Improved Aro object, now only fits one way securing the panels
Imagine bringing a touch of elegance and history into your home with a traditional Kumiko lantern.
It fit most LEDs tealights. If you require larger fit just let me know and i'll adapt.
Easy print.
Supports needed for the roof. The print time is not that different and you can assure a good print. If you use my settings they will come off easy.
Assembly:
Insert the handle on the door. Its really tight, but i didn't need glue. I always try to avoid on my designs.
Start by uniting the door the the side panel using a piece of filament.
Because of the size i strongly suggest you put the filament through first to test the hole.
Insert lantern panels into the base. Its a tight fit.
Make sure the door is facing the base without
Insert white panels into each slot.
Door panel is shorter.
Unite everything using the aro object. It only fits one way. It should be tight.
Finally the roof.
I didn't need but feel free to use glue.
japanese
lantern
kumiko
japanese lantern
led light
candle
tea light
