2025-10-23 03:55:28
14.1k
1.6k
LARGE+BRIGHT Moon Lamp Modern Wavy Base 250mm
@maxim_4198081
This is moon lamp with a modern wavy base. There are a lot of models out there but I wanted a big one with a bright bulb. It is a large size and takes full advantage of the Kobra S1 and other 250mm and larger build plates. I remixed the bulb base for GU10 socket so I could use an MR16 bulb, other GU10 bulbs should work as well, will be much brighter than typical LEDs or Bambu LED kit.
The wavy base has fuzzy texture to give it a nice look. The bulb holder base ideally should be printed from ABS or ASA but PLA should be okay with an LED lamp. The bulb holder will be printed without supports, there is a sacrificial layer you need to break through after printing. The holder is a bit loose locking into the moon but you can add a drop of glue if you move the lamp frequently.
GU10 Sockets: https://www.amazon.com/DiCUNO-Resistant-Maximum-Connector-Packages/dp/B07GVB2P2N/
LED bulb: https://www.amazon.com/Euri-Lighting-EP16-7W5020eG-2-Dimmable-Equiv/dp/B09PB1CG3L/
Lamp cord: https://www.amazon.com/RTNLIT-Button-Polarized-Stripped-Replacement/dp/B0C7BZ65S2/
Click here to check out my XXL bright moon lamp in 320mm size.
Click here for all my other models!
nasa
lamp
moon
lithophane
led
gu10
modern
decor
bedroom
lighting
bright
decoration
nite
night
light
nightlight
atmosphere
shade
lampshade
design
