2026-07-14 21:43:49
619
28
LadyElf – Dark Floral Elf Gothic Statue
@g4brix_1535559
An elegant dark-fantasy elf lady surrounded by large enchanted flowers and twisting branches, designed as a detailed decorative display statue.
LadyElf is a highly detailed fantasy statue featuring an elegant elven woman surrounded by large flowers, buds, leaves and organic ornamental branches.
The composition combines a dark gothic atmosphere with graceful floral elements. The long flowing dress merges naturally into the decorative base, creating a stable and visually rich display piece.
The model is designed primarily as a collectible decorative statue and works especially well with silk, metallic, dual-color or color-shifting filaments, which emphasize the dress folds, flowers and fine ornamental details.
Main features
  • Detailed fantasy elf character
  • Large decorative flowers and buds
  • Gothic and botanical design
  • Integrated ornamental base
  • Suitable as a display or collectible statue
  • Optimized for FDM printing
  • Particularly effective with silk and metallic filament
  • Single decorative composition with many fine details
The model contains thin branches, flower edges, horn tips and other delicate details. Handle it carefully after printing and while removing supports.
Nota di stampa
Recommended print settings
Layer height: 0.12–0.16 mm
Walls: 3–4
Infill: 12–20%
Material: PLA, PLA Silk or PLA Metallic
Supports: Required
Brim: Recommended
Print speed: Reduced for fine details
Use tree or organic supports where possible, especially around the arms, flowers, branches, hood ornaments and projecting petals.
For the best result, reduce support contact density on fragile decorative areas and remove supports slowly using precision cutters or small pliers.
Because of the many thin elements, make sure the filament is dry and cooling is properly calibrated.
Avvertenza da aggiungere
Important handling note
This model includes several thin and delicate decorative elements. Remove supports carefully, especially around the flowers, fingers, branches, petals and horn-shaped details. Do not force the supports sideways, as this may damage the smaller parts.
Support removal note
This model requires a significant amount of support material because of the many flowers, branches, petals and overhanging details.
For safer removal, I recommend using small flush cutters and starting from the top of the model, working gradually downward. Remove the supports in small sections instead of pulling large groups at once.
Pay particular attention around the horns, hair, fingers, flower edges and thin branches. Cut the supports close to the contact point and avoid twisting them sideways, as the finer details can break easily.
LadyElf
elf lady
dark elf
fantasy elf
female elf
elf statue
fantasy statue
dark fantasy
gothic fantasy
flower sculpture
fantasy flowers
botanical fantasy
display model
high detail
FDM
PLA
silk PLA
fantasy decor
elven queen
forest guardian
