2026-02-15 07:49:24
731
32
Lego Compatible Crystallion Warriors
@CastOHS6_2851648
These are some of my custom lego compatible minifigs that I made a while back, let me know if they're any good!
Edit: Remade the hips so that they're stronger, you will need a hand drill set if you want the legs to fit well onto the hips, I believe a 2.5 or 2.8mm drill bit will do, in addition I added some ammo and the necessary piece to make the arm crossbows fully functionable(use strong material for the crossbow part)
Edit 2: added new cannon arms that are more reliable than the crossbow ones
Lego-Compatible
