2026-10-25 23:31:44
33
Little Boo Witch – Chibi Ghost with Cauldron
@drakeforge3d_5567152
A little magic, a little mischief, and a whole lot of ghostly charm!
This adorable chibi ghost witch holds a round cauldron in her tiny hands, ready for a night of Halloween spells. Her oversized witch hat features a curled tip, a buckle, and a sweet bow beside her cheerful face.
Flowing folds and a gently twisting ghost tail create a floating appearance, supported by a matching round base. Soft shapes and a happy expression make this little spirit a charming addition to a Halloween shelf, desk, or cosy autumn display.
Keep her in classic ghostly white, or paint the hat, bow, and cauldron to create your own colourful little witch.
Designed for FDM printing with supports.
   Guide
1. DRY THE FILAMENT
  • Recommendations:
Witch
chibi
Ghost
Cauldron
spooky
cute
halloween
halloween Ghost
little Ghost
