Overwatch Loot Box Storage
- Support-free & Glue-free
- Tolerance: Adjustable (calibrate to your printer)
- Note: Supports recommended for the lid if you are unsure, but it will waste a lot of material.
This is a storage box I designed based on the Overwatch loot box. It requires no supports for printing and no glue for assembly (adjust tolerances according to your printer's accuracy). The print settings for the lid have been optimized, but if you're unsure, you can enable supports for the third print—though this will consume significantly more filament.
