A compact, low-profile square planter with a subtle textured finish.
At 100 × 100 × 40 mm, it’s a great size for moss, small plants, succulents or decorative arrangements. The rounded corners and clean shape give it a modern look, while the textured sides add a more natural character.
There are two print profiles available:
- Thin Edge – a slimmer rim for a clean, minimal look.
- Thick Edge – features a substantial 10 mm wide rim, giving the planter a more solid and robust appearance.
Check the photos to see the difference between the two versions and choose the style you prefer.
The planter consists of two parts: an outer planter and a removable inner pot. The inner pot has drainage holes in the bottom, allowing excess water to drain into the outer planter.
Its low, wide shape also makes it suitable for seasonal arrangements with moss, small branches, pinecones or other decorations.
Features:
- 100 × 100 × 40 mm
- Removable inner pot
- Drainage holes
- Textured outer surface enable Fuzzy Skin feature in slicer
- No supports required
- Easy single-color print
