2026-07-05 08:37:48
2.1k
84
MODULAR CAR WASH AND DETAILING ORGANIZER
@Darren3dprint_3680478
MODULAR CAR WASH ORGANIZER
I was searching for a car detailing organizer and only found canvas ones. I preferred a solid plastic one.that I could customize for my products and tools but could not find one. So I decided to design my own. The organizer is quite versatile and can also be used for boats, RV and many other things.
MODULAR CAR WASH SYSTEM
Central container
The organizer is based around a central container with a handle. The central container can be used to hold various items such as wax, polishing compound or applicators.
Clip on holders
You can clip various holders around the central container - I provided various options. There are two options - side clips on and front/rear clips on. The side clips can either be full or half lenght.
The clip-on holders have a bottom and a top section.
The side mounts can hold many items as seen in the photos including most products used for car wash and car detailing.
Top basket
There is a basket that mounts on the top of the central container. It is meant to be used for towels and other supplies. The upper basket also has holes to hang wet cloths from.
ASSEMBLY
Assembly is quite simple.
You only need two 3/4" no. 6 (4 mm x 20 mm) wood screws for the handle (see photos).
All other components are clipped on and 3d printed.
The handle is clipped on by pulling it up into the slots. You then screw in the screws to lock it into place.. .
3D PRINTING
FILAMENT AND PRINT TIME
The Car was organizer requires a printer with a print capabily of approximately 250x250x250 mm.
Excluding the handle, the central container is 9 inches (225 mm) long by 6 inches (150 mm) wide by 6 inches (150 mm). The side clip-on holders and the top basket add to this..
It requires About 1.1 kg of filament to print and takes about 1 day 10 hours to print.
PRINT SETTINGS
IMPORTANT I upload a print setting files for all my models. The print settings has the parts positioned for correct printing with support painted.
I strongly recommended you use my print setting file. If not, I will not be able to assist you if there is an issue when printing. From experience, many of the issues with printing my models are on account of users not using my print settings.
3D PRINT SETTINGS
I use the following settings and materials to print this model:
Infill % : 15% (no need for more)
Nozzle diameter: 0.4 mm
Layer height: 0.2 mm standard
Walls: The model is set for 2 walls.
Material: PLA or PETG. PETG may be preferable since the organizer will be used outdoors and with water.
ABOUT ME
I enjoy creating 3d models that others can use and appreciate. It is a very fun pastime. I find it very rewarding to see my models downloaded and printed. I put lots of thought, time and effort to create each model print out multiple iterations to make sure it works just right.
If you liked my model and wish to encourage me please give it a like. If you wish you can also help me with my filament costs. You can also use the discount codes listed below. You will save and I get a small commission for certain purchases. Thank you.
DISCOUNT AND AFFILIATE CODES FOR PRINTER AND FILAMENT
I am continuously trying to get discount codes from various manufacturers. Unlike many affiliate links these give discounts on purchases and are more difficult to obtain. In my requests I ask that they give me the codes with the most discounts for users even if it means a smaller commission.
HOW TO USE THE CODES
1.      You need to CLICK ON THE AFFILIATE LINK. The links are usually set up by countries/regions.
2.      Add the items you want to purchase
3.      Enter the DISCOUNT CODE at checkout. The codes vary by month and saving – so check back each month for the latest offers.
4.      You can only use ONE CODE so be certain to enter the one with the most discount
ANYCUBIC – June 26th to August 31 2026
United States - US site
AFFILIATE LINK (CLICK THIS 1ST): https://store.anycubic.com/?ref=gnsbwzea
$30 off $400+ sitewide with code ACSUN30
$25 off $300+  on selected items with code ACSUN25
$20 off $200+ on selected items with code ACSUN20
$15 off $150+ sitewide with code ACSUN15
$5 off $50+ sitewide with code ACSUN10
$3 off $30+ sitewide with code ACSUN3
$10 off – Darren3dPrint10
$15 off – Darren3dPrint15
Australia - AU site
AFFILIATE LINK (CLICK THIS 1ST): https://www.anycubic.au/?ref=Darren3dPrint
$40 off $550+ sitewide with code ACSUN30
$35 off $400+  on selected items with code ACSUN25
$30 off $300+ on selected items with code ACSUN20
$20 off $200+ sitewide with code ACSUN15
$15 off $150+ sitewide with code ACSUN10
$7 off $70+ sitewide with code ACSUN5
$4 off $40+ sitewide with code ACSUN3
CANADA - CA site
AFFILIATE LINK (CLICK THIS 1ST): https://ca.anycubic.com/?ref=Darren3dPrint
$42 off $570+ sitewide with code ACSUN30
$35 off $430+  on selected items with code ACSUN25
$28 off $280+ on selected items with code ACSUN20
$21 off $210+ sitewide with code ACSUN15
$14 off $140+ sitewide with code ACSUN10
$5 off $40+ sitewide with code ACSUN3
SPAIN - ES site
AFFILIATE LINK (CLICK THIS 1ST): https://www.anycubic.es/?ref=fldwnkel
30€ off 400€ + sitewide with code ACSUN30
25€ off 300€ + on selected items with code ACSUN25
20€ off 200€ + on selected items with code ACSUN20
15€ off 150€ + sitewide with code ACSUN15
10€ off 100€ + sitewide with code ACSUN10
5€ off 50€ + sitewide with code ACSUN5
3€ off 30€ + sitewide with code ACSUN3
10€ off – Darren3dPrint10
15€ off – Darren3dPrint15
UNITED KINGDOM - UK site
AFFILIATE LINK (CLICK THIS 1ST): https://uk.anycubic.com/?ref=xhneqmoe
£30 off £400 + on selected items with code ACSUN30
£25 off £300 + on selected items with code ACSUN25
£20 off £200 + on selected items with code ACSUN20
£15 off £150 + sitewide with code ACSUN15
£10 off £100 + sitewide with code ACSUN10
£5 off £50 + sitewide with code ACSUN5
£3 off £30 + sitewide with code ACSUN3
GERMANY - DE site
AFFILIATE LINK (CLICK THIS 1ST): https://de.anycubic.com/?ref=lbrowght
FRANCE - FR site
AFFILIATE LINK (CLICK THIS 1ST): https://fr.anycubic.com/?ref=akeofafb
EUROPE - EU site
AFFILIATE LINK (CLICK THIS 1ST): https://eu.anycubic.com/?ref=Darren3dPrint
ITALY – IT
AFFILIATE LINK (CLICK THIS 1ST): https://anycubic.it/?ref=waimpcbq
POLAND - PL site:
AFFILIATE LINK (CLICK THIS 1ST): https://anycubicofficial.pl/?ref=aakjogpi
ACSUN30
ACSUN25
ACSUN20
ACSUN15
ACSUN10
ACSUN5
ACSUN3
car wash
organizer
car detailing
car wash organizer
car
boat
