2025-10-26 17:04:34
10.3k
782
Magic Cat of the Night · Pumpkin Lantern 夜之魔法猫 · 南瓜灯
@flowercat_5771384
夜之魔法猫 · 南瓜灯  Magic Cat of the Night · Pumpkin Lantern
一开始,我想做一盏万圣节南瓜灯,想着要是能更增加节日氛围就好了。
我突然想到——万圣节怎么能少了猫呢?
当南瓜点亮——这只会魔法的小猫就从南瓜中苏醒。以一盏灯的温度回应黑暗,为夜晚施下温柔的诅咒!
 It all began with a simple wish: to craft a Halloween jack-o'-lantern that could truly capture the spirit of the season.
Then it hit me—what's Halloween without a cat?
And so, when the pumpkin glows to life, this little magical creature awakens from within. It answers the darkness with the warmth of a single light, casting a gentle spell over the night.
它的眼睛会发光,看上去温柔而奇幻。帽子一转,表情也在发生变化(旋转帽子顶部切换几种不同表情)。
 Its eyes glow with a soft and magical light. By simply rotating the top of its hat, you can cycle through a series of charming expressions.
按压它的头能触发灯光的魔法,每次按下都能切换灯光颜色,还会发出轻轻的“咔嗒”声,我非常喜欢这个声音。
A press of its head activates the light's magic, cycling through colors with each interaction. A soft, tactile "click" accompanies every change—a sound I've grown quite fond of.
也可以使用遥控器同时控制两个灯,切换出绿色、红色、紫色、蓝色等灯光氛围,像魔法真的在流动。
For broader control, the remote allows you to command both lamps at once, bathing the room in a flowing cascade of green, red, purple, and blue, as if magic itself is swirling around you.
看!南瓜上还长出了一对大大的翅膀和灵动的小尾巴(尾巴是铰链结构可以动哟),黑色的帽子看上去低调而神秘。
Look! The pumpkin has sprouted large wings and a playful little tail—engineered with a hinged joint for a delightful wiggle. Topped with a black hat, it exudes a subtle yet mysterious charm.
提起把手,南瓜的光晃动着猫的影,仿佛它正跟随你一同穿越夜色,像一位夜晚随行的伙伴。
Lift it by the handle, and the pumpkin's light sways the cat's shadow within, creating the illusion that it is following you through the darkness—a silent companion for your nightly wanderings.
放在桌上,它会悄悄点亮你的夜晚。
它承载了我对万圣节的想象,感受到一点小惊喜和魔法般的快乐!
 Place it on your desk, and it will gently illuminate your evening.
It carries all my imagination of Halloween, designed to bring you a little surprise and a spark of magic joy.
好啦,就是这些啦,希望你会喜欢,记得点赞关注哟~感谢你的支持~!
Alright, that's all for now! Hope you love it! Don't forget to like and follow for more. Thanks for your support!
打印前请阅读:
1.南瓜主体和螺纹连接环两个组件需要开启支撑(配置文件中手绘支撑,支撑类型:普通,支撑样式:紧贴。如果你有更好的打印心得也可以自己修改);个别组件体积较小,需开启裙边。
2.表情组需要多色打印,当然手涂的效果我觉得也很惊艳。
3.把手组件测试耗材为:PLA,要想获得更好的质量可以选择强度更好(PETG)的耗材。
Before printing, please read:
1. The pumpkin body and threaded connection ring components need to be supported (hand drawn support in the configuration file, support type: ordinary, support style: tight fit. If you have better printing experience, you can also modify it yourself); Some components have small volumes and require opening the skirt.
2. The emoji group requires multi-color printing, and of course, the hand painted effect is also stunning.
3. The consumables for the handle component testing are PLA. To obtain better quality, you can choose consumables with better strength (PETG).
套件说明:匹配套件是 遥控 16 色 RGBW 冰球灯,需要的小伙伴可以点击链接查看哟。
如果打印过程中遇到任何问题,可以评论区或者私信我,我会尽力解答;组装说明图我已经上传啦~
组装视频已经更新啦,感谢你的支持和理解~!
https://youtu.be/k9Dd1fvlkeg?si=KDlup79DriqmvGzv
商业许可证:
您可以在我的Patreon上或在Maker World上订阅商业许可证会员资格,感谢你的喜欢和支持~!
If you encounter any problems during the printing process, please feel free to leave a comment or send me a private message, and I will do my best to provide answers; I have uploaded the assembly instruction diagram~
I will also update the video as soon as possible. Thank you for your support and understanding!
Commercial License:
You can subscribe to a commercial license membership on my Patreon or Maker World. Thank you for your love and support!
Halloween
pumpkin
lamp
decoration
cat
万圣节2025
南瓜灯
表情
摆件
装饰
灯光
礼物
gift
LED
蝙蝠
bat
帽子
hat
节日
5.32MB
