2026-08-01 16:56:29
771
11
Magnetic stirrer
@AndyCar_2688600
The magnetic stirrer is a laboratory instrument that mixes liquids using a rotating magnetic field, eliminating the need for direct physical contact and reducing the risk of contamination.
This magnetic stirrer is made using a standard 80mm computer fan connected to a 12V power supply equipped with a standard 5.5mm x 2.1mm jack (positive pole inside, negative pole outside) and a PWM speed controller.
You will need the following parts:
- 12V power supply with a standard 5.5mm x 2.1mm jack
- 80mm computer fan
- PWM speed controller
- 5.5mm x 2.1mm DC Female Panel Jack
- Two 10x3mm neodymium magnets
- Twelve 6x3mm neodymium magnets(stir bar)
You can see it in action here.
Stirrer
science
molecular biology
mixer
magnetic stirrer
laboratory tools
laboratory
biohacking
biology
science education
lab equipment
medical devices
equipment
lab
microbiology
