Bring a powerful dark fantasy boss to your tabletop with Malzareth, a 3D printable DnD-inspired character designed for RPG campaigns, boss fights, display shelves, and fantasy collections.
Malzareth is a mysterious hooded warrior with heavy armor, sharp shoulder details, a skull emblem, and a large scythe weapon. The miniature stands on a rocky base, giving it a dramatic presence perfect for a final encounter, dungeon boss, necromancer villain, or dark guardian character.
This model also includes a matching 3D printed character card with the name MALZARETH at the top and a raised emblem of the character on the front. The blank white panel at the bottom can be used to add your own boss stats, abilities, HP, armor class, lore, or campaign notes.
Included Models
- Malzareth boss miniature
- Rocky display base
- Matching 3D printed Malzareth card
- Blank stat area for custom boss information
- Dark fantasy DnD boss design
- Hooded armored character with scythe
- Great for tabletop RPGs and fantasy displays
- Includes matching 3D printed stat card
- Blank lower panel for custom stats or notes
- Perfect for campaign bosses, villains, necromancers, or dark knights
- Can be printed in one color or painted for extra detail
- Great display piece for RPG players and Dungeon Masters
Suggested Uses
Ideal for:
- DnD campaigns
- Tabletop RPG encounters
- Boss fights
- Fantasy dioramas
- Dungeon Master props
- Display shelves
- Custom character collections
- Painted miniature projects
Custom Stat Card
The included card is designed with a blank section at the bottom, so you can personalize Malzareth for your own campaign.
You can add:
- HP
- AC
- Attack stats
- Special abilities
- Boss phases
- Weaknesses
- Lore
- Encounter notes
Printing Tips
For best results, print the miniature with good detail settings. Resin printing is recommended for maximum detail, but FDM can also work with tuned settings.
Suggested settings:
Layer height: 0.12–0.20 mm for FDM
Layer height: 0.03–0.05 mm for resin
Walls: 3+
Infill: 15–25% for FDM
Supports: Required for the miniature
Material: PLA / PLA+ / Resin
For the card, print flat on the bed for a clean front surface and better color changes if using multicolor printing.
Safety Note
This is a fantasy tabletop model and decorative prop. It is not a toy for small children due to small parts and sharp details.
